Presentation Transmit Rates
kristi.mason
I am having an issue with the transmit rate. Our Presentations are becomeing too poor or unsable. Endoint involved.
SX20
SX20
C60
MCU 4501
Audio TransmitReceive
ProtocolAACLDAACLD
Channel rate61 kbps125 kbps
Jitter0 ms0 ms
Loss0 %0 %
Video TransmitReceive
ProtocolH264H264
Channel rate417 kbps624 kbps
Resolution768x448@30Hz1280x720@30Hz
Jitter6 ms3 ms
Loss0 %0 %
Presentation TransmitReceive
ProtocolH264-
Channel rate9000 bps-
Resolution512x288@30Hz-
Jitter0 ms0 ms
Loss0 %
Thanks Kristi
5 Replies 5
kristi.mason
MCU
Connected at 23:16, Jun 4 2013
Tx: 1280 x 720, H.264, 640k, AAC-LD
Rx: 768 x 448, H.264, 704k, AAC-LD (muted remotely)
Content source
Encrypted - check code: 31F6D56A28EFCFB0
H.323
nsh.merrimack.video@wrs.com
147.11.252.98 (6000)        Connected at 23:19, Jun 4 2013
Tx: 1280 x 720, H.264, 320k, AAC-LD
Rx: 768 x 448, H.264, 256k, AAC-LD (muted remotely)
Content tx: 512 x 288, H.263+, 320k  disable
Encrypted - check code: 902369D8EF5C8F93
H.323
Ottawa 52 Profile
147.11.252.98 (2000)        Connected at 23:19, Jun 4 2013
Tx: 1280 x 720, H.264, 704k, AAC-LD
Rx: 1280 x 720, H.264, 1.09M, AAC-LD (muted remotely)
Encrypted - check code: F6C9CC4867586784
Content channel      Content viewers: 2
DJPEG viewers: 0
Tx: 512 x 288, H.263+, 320k
Rx: 512 x 288, H.264, 704k (encrypted)
Hi Kristi,
Please login to MCU and go to the conference in which endpoints are connected/ are about to join.
Please check the minimum outgoing bandwidth
Sagar
Conference settings
Maximum video size
Motion / sharpness tradeoff
Transmitted video resolutions
Default bandwidth from MCU
Default bandwidth to MCU
Default view family
Use full screen view for two participants
Active speaker display
Media port reservation
Audio notificationsConference timing   Conference status   Join and leave indications
Overlaid icons
Important  participant   Unsecured  conferences
Tunneled  camera control   Layout  changes   Streaming participants
Recording indicator   Audio  participants   Media  quality
Overlaid text
Conference  status   Conference  timing   Join and leave  indications
Text messages   Content channel text  chat
Overlaid logo duration
Conference welcome message
Conference welcome message duration no message set
Time to show participant names
Advanced settings
Audio codecs from MCUG.711  G.722  G.722.1  G.728  G.729  G.723.1
Polycom(R) Siren14(TM)  G.722.1 Annex C  AAC-LD  AAC-LC
Audio codecs to MCUG.711  G.722  G.722.1  G.728  G.729  G.723.1
Video codecs from MCUH.261  H.263  H.263+  H.263 interlaced  H.264
Video codecs to MCUH.261  H.263  H.263+  H.263 interlaced  H.264
ClearVision
Video transmit size optimization
Video resolution selection mode
Video format
Maximum transmitted video packet size bytes
Interlaced video optimization
Video receive bit rate optimization
Flow control on video errors
Don't see yourself in small panes
Don't duplicate in small panes
Automatically make content channel important
Loudest speaker pane placement behavior
Pane rolling interval
Voice switching sensitivity %
Additional audio delay relative to video
Floor and chair control
Incoming calls to unknown conferences or auto  attendants
Failed preconfigured participants redial  behavior
Conferences remain locked when empty
Use conference name as caller ID
Require H.323 gatekeeper callers to enter PIN
Require a PIN for ad hoc conferences
Minimum required PIN length for ad hoc  conferences
Time to wait when setting up ad hoc conference PIN
Advertise out of band DTMF to endpoints
Seems like your endpoint is transmitting poor video and presentation quality. What call bandwith do you use?
You wrote, that you use two SX20 in the call, but only showed us one in the statistics. Is the other one connected to the first SX20? That would at least explain the 448p Video
Regards, Paul
ckelson
On the input setting for the port  you have your presentation source connected on to Sharpness.
