08-16-2006 02:11 PM - edited 03-17-2019 08:46 PM
hi all.
I have 4 lines to the PSTN connected to a FXO card, the problem is when somebody in the PSTN call and hung before they answer the IP phone, the IP phone continuous ringing and the FXO port is not released, to stop ringing and release the port, in need to off-hook the IP Phone
the FXO card is a VIC2-4FXO
the voice-port configuration is:
voice-port 0/1/0
timeouts call-disconnect 1
timeouts ringing 30
timeouts wait-release 1
connection plar 1202
voice-port 0/1/1
timeouts ringing 30
voice-port 0/1/2
timeouts ringing 30
connection plar 1205
voice-port 0/1/3
timeouts ringing 30
Solved! Go to Solution.
08-24-2006 05:03 PM
Have you tried using connection plar opx?
08-22-2006 10:35 AM
what's the software version which you are using ?
08-22-2006 12:47 PM
The Hardware and Software version:
Router 2811
IOS 12.4(4)XC SPSERVICESK9-M
CCME 4.0(1)
VIC2-4FXO
08-23-2006 12:15 AM
Try switching to ground start signaling.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
08-24-2006 05:05 AM
Hi, you need to ask to your provider to add the "Cut On Disconnect" option to each of your 4 lines. This option is also known as COD option.
I had this issue with Bell Canada (DMS-100)
08-24-2006 02:43 PM
Hi.
The problem is when I configure connection plar to a IP Phone, without connection plar the FXO port ir release correctly.
08-24-2006 05:03 PM
08-25-2006 10:40 AM
thanks
The "connection plar opx" resolve the problem
great aid
08-25-2006 03:56 AM
I know... The COD option will fix your issue
