05-10-2017 03:54 PM - edited 03-18-2019 01:06 PM
Hi All,
I am looking for an XML command or configuration code to push passwords to endpoints.
Please advice.
05-10-2017 04:09 PM
You can use configuration templates in TMS to update the admin password on the endpoint, this will also update the password TMS uses to manage the endpoint as well.
Setting: Password
System Type: Other type
It's been asked a few times in the forums, for example: tms-132-set-https-admin-password-through-configuration-template-c-series-codec and tms-configuration-template-ce-830-custom-configuration-changing-passphrase.
05-11-2017 02:48 AM
Hi Patrick,
Thank you so much for these commands,
The below command only works on CE versions, could you please advise the command for TC versions
<Command>
<UserManagement>
<User>
<Passphrase>
<Set>
<Username></Username>
<NewPassphrase></NewPassphrase>
<YourPassphrase></YourPassphrase>
</Set>
</Passphrase>
</User>
</UserManagement>
</Command>
05-11-2017 10:46 AM
The following command only changes the Admin password on the endpoint, on the TC version
<Command>
<SystemUnit>
<AdminPassword>
<Set>
<Password>****</Password>
</Set>
</AdminPassword>
</SystemUnit>
</Command>
I want to change the password of profile with user name (ex:macbeth)
which has user and admin privileges
05-11-2017 01:26 PM
You can update the admin account, but there is no API option to update regular user accounts on endpoints that run TC software, only for CE software. You'll need to login to the web interface and update the user accounts.
05-12-2017 02:46 AM
Thank you Patrick
05-12-2017 03:49 AM
is there an XML command to add or delete users in CE version?
05-12-2017 07:58 AM
User accounts must be managed from the endpoint's web interface, there are no API commands to create/edit/delete users. The only command available is to change a user's password.
05-11-2017 12:53 AM
Setting the passwords on multiple devices would be very using Powershell & Posh SSH. It would need a CSV input of IPs & current passwords and would just use a for-each loop to change the passwords on each device
05-11-2017 02:24 AM
Thank you for the reply, could please let me know the instructions and commands used to push the password
