Question on C60 Multi-Site Layout
chanhontung
Dear Expert
I have a question on C60 Multi-Site call using C60 as a host.
It there a selection of layout like Edge 95?
My near end site view is not in the Layout and I go through some administrator document, it doesn't seem metion on multi-site Layout selection.
Is C60 capable to have a layout like "4-splite" as Edge 95?
Thank you
Best Regards
Tung
3 Accepted Solutions
Jens Didriksen
Level 9
Level 9
C60 running software version TC6.0:
You can also make your own layouts using the TC Console:
http://developer.cisco.com/web/telepresence-developer/tools/integrators/tc-console
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Hi Chan,
Yes , C60 is capable to have 4 Site Party Call provided the C60 has MultiSite Option Key installed and as Stated by Jens. You Can also creat your layouts using TC Console Software available on internet.
Saurabh
No, you "only" get 3 windows, I like that much better since it allows each participant more screen realestate.
However, you can have selfview as PIP, i.e. in the bottom right hand corner which puts in a less distracting position.
If you have dual displays then lay-out changes quite a bit when not sending a presentation, as you will have two participants on one screen and one on the other.
Once a presentation is started then they all go to the one screen, which leaves the presentation on its own screen.
/jens
5 Replies 5
Jens Didriksen
Level 9
Level 9
/jens
Hi Chan,
Saurabh
Dear Jens and Saurabh
Thanks for the help
I have play around with the TC Console a bit.
But in software version TC6.0 the selfview is excluded in the multipoint layout.
So that is the way it is? I can't have the selfview include in the multipoint layout?
Thank you
Tung
/jens
Thank you very much Jens!
