Random conference alias in TMS
prlux2012
I'm using TMS 14.6.0 + TPS 4.1 + Conductor 3.0.2
Is there anyway to create a conference with a random alias ?
Actually I'm using the current incremental alias, but I would like to use prefix+random alias in order to secure my solution. Any suggestion ?
Patrick Sparkman
The only way is to use an incremental alias, where TMS will use the first available number in the range you set it to use in Conductors extended settings whenever booking a conference.  There isn't a way at this time to have TMS make the generated alias random or not repeat a previously used alias.
It was brought up over the years by several people asking about such a feature, being able to use random or non-recurring numeric IDs, but I don't think it went anywhere.  Below is one such discussion from a few years back.
how-avoid-numeric-id-repeating-mcu-based-call-when-scheduling-tms
If this is something you'd want, contact your Account Manager and see if they can open a feature request for you. I would, and know of some others that would +1 the request.
Patrick Sparkman
Thanks Patrick
Very clear, it can be a real security issue if PIN code is not used, as suggested, I go to the feature request.
