08-01-2011 11:43 AM - edited 03-17-2019 10:24 PM
Dear All,
I am new to UC 520 Call Manager Express and Cisco Unity Express. I would like help in solving the following problems encountered during the config of the latter:
1. Call Transfer
- When I transfer a call, I need to know if the other person to whom the call will be transferred is available or not,
- if possible i should be able to put the current person on hold and call the other person and see if he is available or not before doing the transfer
- if ever a call is being transferred and the other person is busy or unavailable, the call should be reverted back or forwarded to another number instead of going to voicemail.
2. Configuring phones for call conferencing.
Please note the following details:
Unity Express Version being used: 3.0
Thanks in advance
08-01-2011 02:37 PM
1. In order to get transfers working the way you like, ensure you create ephone-dns as 'dual-line' - this allows one call to be on hold whilst a 'transfer' call is made outbound. Also ensure transfer-system full-consult is configured under 'telephony-service' mode. Basically transfers then are two-step - whilst on a call, hit transfer then dial the target extension. If they answer, announce the caller and hit 'transfer' again, or hit 'end call' to go back to the original caller.
2. You can enable three-party conferences by setting 'max-conferences' under telephony-service. It works the same way as transfer; hit 'Confrn' to start whilst on a call, dial another phone, and then when they answer Confrn again to set up the conference.
Aaron
Please rate helpful posts..
08-02-2011 07:57 AM
Thanks a lot, above solution works fine for me.
