REGISTER MXP1000(h.323/SIP) TO CALL MANAGER 8.6.1
Chet Cronin
Level 4
Level 4
I am sure this is a simple fix but does anyone have a cut sheet on setting up the call manager to register an MXP1000 (either H.323 or SIP) ??
I know where to set the CM settings on the MXP.   Any white paper or procedure would be appreciated ...
Thank you.
Chet Cronin
craig chester
Hi Chet
You should find the bottom section of this post useful, it covers all versions of CUCM 8.
https://supportforums.cisco.com/document/100211/how-convert-mxp-1000-sccp-m2x-firmware-mxp-1000-f9x-firmware
craig
Problem now is the CM see's the MXP but will not register.  Registration "Unknown" and we can call the MXP from a VOIP phone but can't call out from the MXP until it registers to the CM ???
Any IDEAS???
Chet Cronin
Rajkumar Yadav
Level 4
Level 4
Hi Chet,
Please follow the below link for the details to get the MXP  1000 configured with CUCM.
https://supportforums.cisco.com/discussion/11765151/configuration-tandberg-mxp-1700-integration-cucm-h323sip
If the SIP endpoint does not list in the CUCM, then you add the devices as third party SIP endpoint with advanced sip Profile.
Please try and let us know how it goes.
Raaj
Problem now is we see it registering from the MXP SIP status then failed.  Error is failed to send 1 of 1 ???  We are trying to register it as a SIP device.   URI is DN@IP address also the server status states:  timeout.
Registration Interface:   cause - failed to send (1 of 1)
-----------There is mentioned a "user" account and pwd on the CUCM... What permissions is the user account???
Here is the config:
MXP1000 F9.3.4
SIP Mode = ON
Display Name: NAME
SIP Address (URI) DN@IP address of CUCM Pub
Server Discovery: Manual
Server Address:  IP Address of CUCM Pub
Server Type:  CISCO
Transport: Auto
Verify TLS: Off
--------------------SIP Auth-------------
User Name:  NAME (Set from the CM)
User Password: PWD (Set from the CM)
CM config
Device is Active
MAC: Mac
Descript: VTC
Device Pool:  Custom Device Pool
Common Phone Profile:  Standard Common Phone Profile
Owner User ID: Mac
Use device pool calling party:  checked
Retry Video call as audio: checked
logged into hunt group: checked
---------------------Protocol specific information--------------------
Presence group: Standard Pres GP
device security profile: third-party sip device advanced - standard sip non-secure prot
sip profile: vcs-sip profile
digest user:  mac
Chet Cronin
