05-30-2015 06:53 AM - edited 03-18-2019 04:32 AM
Occasionally I will see an error in my Expressway Core related to the XMPP router connection to the IM&P server. A restart of the Expressway has always fixed it, but I was wondering if there was a way to restart that service without restarting the entire box.
Thanks, Mike
Solved! Go to Solution.
05-30-2015 11:19 PM
Hi Mike,
You can try the following and see if it helps:
05-30-2015 11:19 PM
Hi Mike,
06-01-2015 06:08 AM
Ahhhhh.... Don't know why I didn't notice that before. I'll make sure to try it the next time the connection is down. Thanks much!
06-10-2015 12:09 PM
Yep, confirmed that this works. Thanks.
06-10-2015 08:49 PM
Good to know that, thanks for the update.
Manish
