Room Kit EQ and PRO with Quad and PTZ cameras
Faisal Saoud
Does Room Kit EQ or Pro support dual camera with two PTZ 4K, If yes, Is an external switch required
Jonathan Schulenberg
Yes. In the EQ a Quad Cam and two PTZ4Ks will consume all HDMI inputs, so you’ll have to use the USB-C input if you want a wired content input. An external Ethernet switch is only required if you run out of link local ports on the codec.
