room kit pro: disable selfview when moving/switching cameras
arjan.de.goede
Is it possible to disable the selfview window (picture in picture) when moving/switching the camera from the touch panel?
So that we can pan and zoom the camera during a presentation without seeing the camera selfview overlapping the presentation on the large screen (which everyone can see in the room).
Of course when we escape from the camera settings on the touch panel, the selfview disappears, but it would be nice if we can keep the camera settings open all the time , without seeing the selfview.
George Sotiropoulos
I am not sure if i get right the question here but you can toggle the selfview on and off using the touch controller.
To hide the selfview, you can tap the camera icon and deselect the selfview option.  Additionally, you can adjust the selfview position or toggle between full screen and picture-in-picture modes
Hope the above helps,
gsotirop
If I understood your problem correctly, when you access the camera settings or make changes to the camera, the self-view starts automatically, and you don’t want that. AFAIK , that’s how it’s designed to work—when adjusting the camera settings, the self-view activates to ensure the settings are applied as intended. Without self-view, how would you confirm that the settings have been properly implemented? I’ll need to check the devices in my office to see if there’s an option to disable self-view while configuring the camera
Response Signature
