05-07-2019 11:02 PM
Greetings,
I have on premises collaboration architecture which includes - CUCM, IMP, Expressway C & E and CMS servers.
At present I have 11 Room kits which are registered locally to CUCM as video endpoints, also I have jabber desktop MRA users.
I have been asked to install new additional room kits and DX80s to remote location where I don't have network connectivity to my collab servers. Only internet is available & I want to register the Room kits as MRA. How to achieve this ? I am unable to find any documents on this topic.If anyone has done it please share the procedure and experience.
Thank you.
Solved! Go to Solution.
05-09-2019 10:46 PM
If you are using public CA certs on Expressway-E and your jabber MRA is working fine,
then you just need put the root CA certs (including intermediated CA certs as well if any ) on endpoints and provision through expressway by putting expressway-E FQDN and username and password that you set on end user page.
And yes you need to assign the user to device phone page as well as associated the device on end user page as well.
Please refer the below link the configuration will be same in case of DX/room kits as well-
Please rate if it is helpful...
05-08-2019 05:13 AM
05-08-2019 10:36 PM - edited 05-08-2019 10:39 PM
Thank you Mike for the reply.
So If I understand correctly, I will be doing following :
1. I need to register locally to CUCM.
2. Then take the device to remote location and do mentioned web admin settings.
User ID and password are the ones which is configured on End User Configuration webpage, Right ?
But if I do this I need a license to allocate device with user ?
I have ordered TP room license with Room kit, it will suffice my requirement ?
Please let me know.
05-09-2019 10:46 PM
09-04-2019 10:37 PM - edited 09-04-2019 10:39 PM
Thanks all for help.
Devices got registered successfully & I didn't need to put any certs in the devices.
My Public CA was trusted by devices firmware natively.
05-11-2019 04:35 PM
09-09-2019 10:33 PM
The link mentioned does not work try this:
