RoomAnalytics - No Events in xevent to register to?
RenzKanwischer
I am playing with the RoomAnalytics feature currently. It works quite well polling the values regularly via xstatus.
To be more scalable I want to use the HTTPfeedback mechanism and register a webserver to collect the change events. But xevent is not showing values for RoomAnalytics. Have I missed something?
Renz
Magnus Ohm
This is a Status context and not event, but I agree it may not be so intuitive. So in order to achieve what you want you need to register a status expression that looks something like this:
xCommand HttpFeedback Register Expression: Status/RoomAnalytics/PeopleCount ServerUrl: http://yourserver/api/api.php Feedbackslot: 1 Format: json
/Magnus
Magnus Ohm
/Magnus
Hi Magnus,
thanks for the reply. I was not aware that I can use these status expressions as well. I will try that.
Renz
Update: It is working now. Thanks
