07-07-2019 11:29 PM
I have a question about system log of Roomkit Mini.
System log that can be seen from web UI, Maintenance -> System Logs.
In application.log, compared to other devices like Room Kit, SX20 and so on, only Roomkit Mini looks output huge amount of logs like these:
SipMedia I: SipmProfile::update, ix: 1, vendeo: 5, isFirst: false, isVcs8: false
Is this a normal behaviour or some kind of wrong configuration on device, Cisco UCM or TMS?
Any information would greatly help.
Thanks.
11-14-2019 02:12 PM - edited 11-14-2019 02:14 PM
SipMedia I: SipmProfile::update, ix: 1, vendeo: 5, isFirst: false, isVcs8orLater: false
I have also seen this on MX300 G2 devices.It is spamming the logs and causing overwrites.
03-27-2020 05:05 AM
“ These lines are there because the endpoint is sending keepalive to the CUCM every 120secs (default CUCM keepalive time).
As far as I know ix: 1 means ix is supported, vendeo: 5 means CUCM (vendeo:1 is VCS), isFirst: false because this is not the first registration, if first registration, you will see this as true. isVcs8orLater: false, cause you are not registered to VCS”
