RTMT versions 12.5/14
ziqex
Level 4
Level 4
I wanted to ask if I need two separate RTMT version if I want to collect logs for both 12.5 and 14 ccm infrastructure. If I install RTMT from plugins ccm system version 14  would I be able to collect logs for both types of system version?
Thank you.
Daniel
You will use two separate applications.
One for 12.5 and second for 14.
BR Oleksandr
BR Oleksandr
Cisco should really think about making the RTMT backwards compatible like it is the case with ASDM software.
Thanks for your reply
You can have both versions run on the same PC by installing them into different directories. -- Maren
