saving contacts in Ex90 through ssh
gavin han
I don't have TMS so I'll to save contacts manually into Favorites. how do I save it through ssh?
I used following command but it didn't work:
xCommand Phonebook ContactMethod Add  ContactId:Abc Number:sip:123@abc.com Protocol:SIP
OK
*r PhonebookContactMethodAddResult (status=Error):
Description:  Nonexisting PhoneBookEntry
** end
Hi gavin !
You use the API commands for the C Series.
I do not know whether to apply this API command to EX90.
First you must create a folder to add this folder to the local phoneboock. (its aplicable for C40-60-C90)
Then create name for this folder and add user...
Many useful things and documentation you can be found at http://developer.tandberg.com
Now I do not have EX90 for test your question.
br. Oleksandr
Dharmesh Nandoria
try this command ,
xCommand Phonebook Contact Add Name: ABC Number:abc@xyz.com Protocol:sip callrate:768
kind regards,
Dharmmesh
Garvan Long
you dont say how many endpoints you have, but if you have 3 or less TMS is free for 3 systems with the trial key.
If you have more than 3 and you have lots of contacts to add then TMS is a must.
I have tried this on an E20 but not on the EX sereis where i created 1 local  entry on an E20 then using SCP found the phonebook file, took an offline copy and created all the contacts i required and then copied it back to the E20.
