Scheduled meetings in CMS are not appearing in CMM
Genadi
Hello to everyone,
I have CMS 3.8 and CMM 3.8. When i schedule a meeting in CMS via web app i can't see that meetings in CMM.
I can see meetings only in case if they are active but scheduled meetings are not appearing as it was when i used TMS server.
Is it possible to sycnronize scheduled meetings to CMM ?
Genadi
Cisco tac reported
"Hello Genadi, from what I can tell when you schedule the meeting using CMS Scheduler component, the CMM will not know about it initially. CMM only polls TMS for scheduled meetings or then knows about the active meetings by polling CMS. "
So it seems that it's not supported feature
6 Replies 6
Did you add all CMS nodes with API integration port at CMM? CMM should fitch all specs info from CMS database
What do you mean in API integration port at CMM?
I have only one cms node with configured callbridge,webbridge and scheduler.
At CMM GUI >> servers , did you add this CMS node IP address with web admin port ( ex: 445)? Also at CMM GUI , CDR make sure you added CMM FQDN
Did you add  a CDR Receiver in CMM ?
it shold be https://<CMM FQDN>
Please let us know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Yes. CMS server can ping that fqdn with no issue.
Genadi
Cisco tac reported
