08-07-2015 12:49 PM - edited 03-18-2019 04:50 AM
Hi team,
I am not sure if I should post this question here, but I am running TMS 14.4.0 and TMSXE 4.0 and would like to upgrade both. I would like to upgrade the TMS to 14.6.2 and the TMSXE to 4.1, can any one tell me what I should upgrade first. I have taken a look at the following link and it shows that the TMSXE should be first. I am some what confused because other told me the TMS should be first, can some one verify,thanks. p14
Solved! Go to Solution.
08-09-2015 11:15 PM
As per the TMSXE Deployment guide ( page 24 )
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tmsxe/install_guide/Cisco-TMSXE-deployment-guide-4-1.pdf
You must also upgrade to the required version of Cisco TMS before initiating any installation or upgrade of Cisco TMSXE.
Manish
- Do rate helpful posts -
08-09-2015 11:15 PM
Manish
08-10-2015 03:39 PM
Thanks for your response Manish.....
