Should TMS be upgraded before TMSXE ?
kingfish1802
Hi team,
I am not sure if I should post this question here, but I am running TMS 14.4.0 and TMSXE 4.0 and would like to upgrade both. I would like to upgrade the TMS to 14.6.2 and the TMSXE to 4.1, can any one tell me what I should upgrade first. I have taken a look at the following link and it shows that the TMSXE should be first. I am some what confused because other told me the TMS should be first, can some one verify,thanks. p14
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tms/install_guide/Cisco-TMS-install-guide-14-6.pdf
Manish Gogna
As per the TMSXE Deployment guide ( page 24 )
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tmsxe/install_guide/Cisco-TMSXE-deployment-guide-4-1.pdf
You must also upgrade to the required version of Cisco TMS before initiating any installation or upgrade of Cisco TMSXE.
Manish
- Do rate helpful posts -
Manish Gogna
Manish
Thanks for your response Manish.....
