Skype for Business and Standalone Cisco Video endpoint
ArSh21
Is it possible to join Skype for business meetings from a standalone Cisco video endpoint (ex: MX300 or Room55) ?
Does it require additional infrastructure? What about licensing ?
Kind regards.
8 Replies 8
You will need additional infrastructure to enable you to connect proper Standards Based Video Conferencing Endpoints with Skype for Business.   This could be any or all of the following:- Cisco Meeting Server, Cisco Webex, Cisco VCS with Microsoft Interoperability Option, Pexip Infinity.  Any of these can do the translation from one environment to the other if configured correctly.  The two cannot direcly interface together.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
How is it possible with Cisco VCS with Microsoft Interoperability Option ?
is there a document I can follow ?
Thanks!
Please follow the below link for Cisco VCS and Microsoft integration-
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/config_guide/X8-11/Cisco-VCS-Microsoft-Infrastructure-Deployment-Guide-X8-11-1.pdf
Thanks.
Please rate if it is helpful...
If you only have a small number of TelePresence endpoints, then the "Cisco VCS with Microsoft Interoperability Option" is probably not the best answer as it is extremely expensive.
But, if you do want to do so, there is a Deployment Guide on the Cisco Web site - see https://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/config_guide/X8-11/Cisco-VCS-Microsoft-Infrastructure-Deployment-Guide-X8-11-1.pdf
Wayne
Currently only 1 Telepresence is required. Liek you said the VCS is expensive for such a small deployment.
Which one's easiest?
None of the options are "easy".  Each one has its differences, limitations and challenges.  None are particularly easier than others.
It gets even worse if you need to talk to Microsoft Teams - so avoid that if at all possible at this point in time (unless you pick the Pexip solution).
Wayne
