Spark Room 70 Dual - Adding Additional Camera
Support987
Hi All,
I was just looking to know what the process is for adding an additional camera to a Room 70 Dual setup?
Is this possible and if so can users pick between the two cameras, for example which one is the Main Source?
Also can both cameras allow for camera control even though there is only one camera control Ethernet port?
Any help would be greatly appreciated.
PJMack
Level 7
Level 7
This is covered in the admin guide - yes you can add a second camera (P60) and you will need an ethernet switch. Go here - page 51
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/ce94/room-70-administrator-guide-ce94.pdf
