Speakertrack 60 error message
Michael Wehle
Hi all,
we are having issues with our Speakertrack 60 camera as the left one brings up an error message instead of videopicture:
Warning: Camera problem - video is stopped
timestamp: 04Z: Camera Malfunc_ Autoexposure
timestamp: 04Z: Camera Malfunc_ Motor
timestamp: 04Z: Camera Malfunc_ Motor Iris
timestamp: 04Z: Camera Malfunc_ System critical
Camera SW version: HC7.3.3.c84180a, 2015-06-12
What we did already to solve the problem and as posting here the issue, nothing at all helped:
- power cycle camera and speakertrack unit
- camera factory reset
- speakertrack unit factory reset
- exchanged left with right camera, but problem and error warning keeps on left camera. so its obvious its not the camera itself.
- software upgrade to TC7.3.4
the warning dissapear for a time being, but sure latest the next day appears again.
exchanged Speakertrack unit as well as camera. Now seems to work fine.
Sure we´ll keep an eye on it.
Thanks for help and have a nice weekend.
7 Replies 7
Patrick Sparkman
Sounds as if you might have a faulty SpeakerTrack base, since it's obviously not the camera since you swapped them and the issue didn't follow the camera.  Did you perform a software upgrade recently, or did this just start happening.  Suggest you contact TAC, they can help figure out if it's faulty or if there is a solution that doesn't require a replacement.
Chad Patterson
Michael,
Those error messages are almost always linked to hardware failures on the P60 cameras. Like Patrick mentioned, open a TAC case with a log bundle from the unit and we will get you sorted out.
Thanks a lot, and apologize for late reply.
we had opened TAC and wait for process ongoing.
Thanks for the update Michael, let us know what TAC says.
update:
Speakertrack Base exchanged, approx 1 day working well
Camera exchanged, approx 1 day working well
now the same message appears for the second (original) camera....
Hi, as an update.
after exchanges it seems to work well now.
thanks for all your interest and comments on that.
