SQL Server for TMS
We are going to install TMS v15 and we will use an SQL external. What communication ports, protocols, and services that are required for the communication between the TMS and SQL server?
Lan
2 Accepted Solutions
As per TMS installation guide using external SQL server, for network requirement the latency between the Cisco TMS server and the SQL server must not exceed 20 ms.
For the ports used by TMS Refer to this guide under page 13.
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tms/install_guide/Cisco-TMS-install-guide-14-6.pdf
For SQL connections, the TCP port used by a default SQL server instance is configurable, and the port used by a named SQL server instance is dynamic, changing whenever the service restarts.
For instructions on making your SQL server listen to a particular port:
https://technet.microsoft.com/en-us/library/ms177440.aspx
Acevirgil
As you're going with TMS 15, check out the TMS 15 Installation and Upgrade Guide and the TMS 15 Administrator Guide.  The requirements for Windows and SQL versions for TMS 15 are slightly different to those linked by Ace for TMS 14.6, although the actual SQL communication ports should be the same.
As a general rule, TMS and the SQL server should both be on the same network, so you shouldn't need to worry too much about ports through firewalls, etc.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Acevirgil
Thanks for the info Wayne and Ace
Wayne
Wayne
