SX-20 Registration with Expressway-e over Internet
ibrahim.kayali
Hello ,
I'm looking for cisco documentation that explain SX-20 supports expressway-e registration over internet or not ? Did you test this endpoint for this purpose and do you have any document about this issue ?
Regards ,
Ibrahim.
5 Replies 5
Rishabh Gupta
HI Ibrahim,
Please refer these documents :
  1. Collaboration Edge TC-based Endpoints Configuration Example : https://www.cisco.com/c/en/us/support/docs/unified-communications/expressway/118696-config-cucm-00.html
  2. Registering a SX10 (and TC based endpoints) through Collab-Edge MRA : https://ciscocollab.wordpress.com/2015/11/22/registering-an-sx-10-and-tc-based-endpoints-through-collab-edge-mra/
Rishabh Gupta,
*Rate the response if found helpful.
Hello Rishabh ,
Thanks for explanation. However , I need the SX-20 or SX Series support this feature or not.
The documents you sent not contain this information exactly.
Regards ,
Ibrahim.
HI @ibrahim.kayali,
Yes, the document is applicable for all endpoints running TC / CE software.
You can follow it for SX20 as well.
Rishabh Gupta
Hello Risbabh ,
Thanks for your confirmation. Expressway-e certificate is signed by COMODO . This 3rd Party CA supports this feature ?
HI Ibrahim,
Yes, "Comodo CA Limited"supports this.
It is already there in the list of Pre-installed CAs in endpoint.
See below:
Ragards,
Rishabh Gupta
-Rate the response if helpful
