SX20 - Can't access Gui Via Https
eliran mor
Hello
We have several Telepresence units SX20 (more then 10)
all of them have Tc 7.3.16 version
registered to CUCM 8.6.2 and provisioned with TMS ver 14.3.2
With most units i can access the gui via https but in 3 units i can access only via http (https get timed out)
the units are on the same subnet and Vlan so its not a reach ability  or access issue
obviously i want to access all of them via https
the configuration of the networkservices are the same (https turned on) on both working and none working device
the configuration on the CUCM are http+https on both working and none working device
all the devices have valid certificates
factory reset did not help
what am i missing ???
Thank you
Anurag Srivastava1
Can you compare on working and non-working endpoint under security and service certificate ?
Whether the HTTPS service is on for non-working endpoints for respective CAs.
Please rate if it is helpful...
Please rate if it is helpful and mark as accepted solution if applicable....
On both https is set to on , on the https section of the security section and both have a valid certificate
