SX20 Error: Touch Panel Not Detected
Scott Nieto
I have an SX20 setup to use with remote but I keep getting an error message on the screen that says "Touch Panel Not Detected". And, the web GUI says, " ERROR: Control System Connection
The system is configured to use a control system, but no control system is detected."
The remote is working fine. Anyone know how I can remove this error?
Scott Nieto
Solved: I found that my Peripherals was set to Touch Panel 1 when it should have been set to 0. Thank you.
Michael Rubin
make sure the touch panel is on the right subnet and or Vlan communicate with the codec (touch panel IP information)
PJMack
Level 7
Level 7
What software version are you running? There were at least a couple that had a bug where you couldn't clear that message without adding a panel.
Scott Nieto
