SX20 - Full presentation with Far and Near as PIP?
We have a SX20 Video conferencing unit setup with a single projector. Connected via a VGA cable to the DVI port using the supplied VGA to DVI convertor. The connection goes through a VGA switcher appliance.
While in presentation mode, we would like to use the "Overlay" feature whereby the Presentation is Maximised, the Selfview is in the right left corner(PIP) window and Remote site/Far End to be displayed in the left top corner(PIP).
From the icon in the Menu it seems possible. How can we achieve this? We have juggled with the settings with no avail. Can anypone advise?
eichrist
What software version are you using?
This will for sure be possible in the upcoming CE8 software, both with remote control and the Touch Panel 10 - but it should be the default config if you select Overlay and have the presentation in full view.
BR
Eivind
