SX20 Recent call logs
support0219
I have  SX20 , so i wanted to see and back up call log/recents. right now i have a software version of TC6.0.0.876266. when i log in from web browser,  there is no option for  recent  call. what seems to be the problem
6 Replies 6
Patrick Sparkman
They added a "History" tab on the web interface's call control page starting with TC6.1 (they renamed it to "Recents" in TC7.1), however there isn't an option to download that history.
Using SSH, there is an "xHistory" command that will output all call history, though the formatting might not be what you're looking for.
There might be some call history contained in the endpoint logs under Diagnostics > Log Files, but not sure which logs might contain the call history if any.
Further to what Patrick has said regarding the xHistory command, it'll only show you the last 100 calls, so, if you have a busy endpoint, it may not have everything depending on how often you're trying to capture it.
I'd also strongly recommend that you update your SX20 from TC6.0 as there are a number of security vulnerabilities in that older software version.
If you have an active service contract on your device you should be able to download the software from the Cisco Download Software Site.  If you do not have an active service contract, you can contact the TAC referencing one of the recent security advisories such as http://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20140605-openssl, and you should be able to get a "free" upgrade to the new TC7 software.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
xHistory Command : what are the command line and how it works, to download the software
If you have an SSH client, such as Putty, log into the SX20 with the admin account and enter the command "xHistory".  If you want to download a copy of the call history, turn on logging in the application before typing the command.
As an alternative to SSH, you can use Telnet, but you will need to turn it on first as it's disabled by default.  Telnet can be turned on under the NetworkServices options either by using the SX20 web interface or remote.
i have followed all your instruction and it works but the problem is not showing the recent call IPs, it shows only call counter
*h xHistory CallLogs Recent 40 CounterMissed: 0
*h xHistory CallLogs Recent 43 Counter: 3
*h xHistory CallLogs Recent 43 CounterMissed: 0
*h xHistory CallLogs Recent 44 Counter: 1
*h xHistory CallLogs Recent 44 CounterMissed: 0
*h xHistory CallLogs Recent 45 Counter: 1
*h xHistory CallLogs Recent 45 CounterMissed: 0
*h xHistory CallLogs Recent 46 Counter: 1
*h xHistory CallLogs Recent 46 CounterMissed: 0
*h xHistory CallLogs Recent 47 Counter: 1
*h xHistory CallLogs Recent 47 CounterMissed: 0
*h xHistory CallLogs Recent 48 Counter: 1
*h xHistory CallLogs Recent 48 CounterMissed: 0
*h xHistory CallLogs Recent 49 Counter: 1
*h xHistory CallLogs Recent 49 CounterMissed: 0
*h xHistory CallLogs Recent 51 Counter: 2
*h xHistory CallLogs Recent 51 CounterMissed: 0
*h xHistory CallLogs Recent 54 Counter: 3
*h xHistory CallLogs Recent 54 CounterMissed: 0
*h xHistory CallLogs Recent 55 Counter: 1
*h xHistory CallLogs Recent 55 CounterMissed: 0
*h xHistory CallLogs Recent 56 Counter: 1
*h xHistory CallLogs Recent 56 CounterMissed: 0
*h xHistory CallLogs Recent 57 Counter: 1
*h xHistory CallLogs Recent 57 CounterMissed: 0
*h xHistory CallLogs Recent 58 Counter: 1
*h xHistory CallLogs Recent 58 CounterMissed: 0
*h xHistory CallLogs Recent 63 Counter: 5
*h xHistory CallLogs Recent 63 CounterMissed: 0
*h xHistory CallLogs Recent 64 Counter: 1
*h xHistory CallLogs Recent 64 CounterMissed: 0
*h xHistory CallLogs Recent 65 Counter: 1
*h xHistory CallLogs Recent 65 CounterMissed: 0
*h xHistory CallLogs Recent 66 Counter: 1
*h xHistory CallLogs Recent 66 CounterMissed: 0
*h xHistory CallLogs Recent 67 Counter: 1
*h xHistory CallLogs Recent 67 CounterMissed: 0
*h xHistory CallLogs Recent 68 Counter: 1
*h xHistory CallLogs Recent 68 CounterMissed: 0
*h xHistory CallLogs Recent 71 Counter: 3
*h xHistory CallLogs Recent 71 CounterMissed: 0
*h xHistory CallLogs Recent 72 Counter: 1
*h xHistory CallLogs Recent 72 CounterMissed: 0
*h xHistory CallLogs Recent 74 Counter: 2
*h xHistory CallLogs Recent 74 CounterMissed: 0
You can download the history of calls using putty.
On putty, use SSH to connect to the system.
1. Type the IP address of the SX20 with default port 22.
2. Click on Logging.
3. Under Logging, tick on All session output.
4. Rename the file.
5. Click Browse where you want to save the file.
6. Click Open to start capturing the log files.
7. Login to your SX20 using admin credentials if required. Type xHistory and it will show the call history and automatically captured and saved as text file.
Refer to page 18:
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/quick-set-sx20/tc6/api_reference_guide/codec-sx20-api-reference-guide-tc63.pdf
8. Close the SSH session and open the file using wordpad or notepad.
regards,
Acevirgil
