SX80 || Factory reset
lAhmed Saadl
Hello Dears,
I need to perform a factory reset on SX80, but I am unable to do so, as this model is different from others. Attached are the relevant files. Can you please provide instructions on how to factory reset this particular model?
b.winter
Maybe it doesn't work, because it's not a SX80?!
It clearly states "Tandberg TTC6-10, which is obviously not a SX80, therefore the factory process is probably different...
Perhaps it's a bit confusing, thanks for guide. Is it possible to be directed on how to reset it?
