10-13-2016 09:05 AM - edited 03-18-2019 06:28 AM
please i have an issues with sx80 ,
First :-
it's connected with 17 microphones thru audio mixer ( 2x DMP 128 ) , taken the output from the mixer going to microhone 2 in sx80 then i configured microphone 2 ON from SX80 and it's working but the problem is always i have to make microphone 2 ON manualy after every call , i mean when i make a call the far site can't hear me till i make microphone 2 ON then after the call it's going OFF again .
Second :
when i making call multi site call from sx80 with two other i can't see the camera for the two other sites at the same time i can see only camer for one site , but what i need i need to see the camera for the two far sites on the screen .
Thanks alot
10-13-2016 11:41 AM
Why not use the first microphone input, why use the second?
I have an SX80 in my office, and the second microphone doesn't turn itself off from what I can tell. If you take a look at the logs, do you see where it's being turned off after a call?
Regarding your second issue, Multistreaming, see the CE8 Release Notes on pg 38, where you can have participants displayed across both screens during a video conference is only supported when the call is utilizing a TelePresence Server. However, if you're running TC software, you can use the compositing feature of TC Console.
10-14-2016 03:42 AM
Thanks a lot patrick for your kind reply ..
-Yes i will check the logs for the microphone problem
- regarding to the multi streaming issues , i don't have telePresence server only i have SX80 with multi site licence connected to one screen calling 2 other sites ( C40 ) and i receiving only 1 video stream for 1 site but i need to receive the cameras for both two sites ?
thanks a lot
10-17-2016 07:32 AM
With the Multisite feature, you'll be able to see both participants, but they will appear together on the same screen.
When the second participant is connected, is it audio only?
Can you confirm that the Multisite option key is installed?
