SX80 - Remove the add button
josumart
SX80 - they want to remove the add button that shows on touch panel as mentioned on the following guide:
Page # 26 step 2 (Tap Add)
 http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/ce83/touch10-sx10-sx20-sx80-mx200g2-mx300g2-mx700-mx800-user-guide-ce83.pdf
They want to remove this option (button)
Set multipoint mode to off on SX80 configuration but add button continues showing up
Is there a way or not ?
Thank you.
Patrick Sparkman
There is always going to be an add call button, Cisco endpoints can support up to 2 calls: 1 video/audio and 1 audio only.  There isn't any way to disable the audio only call.
Patrick Sparkman
