Syslog capture on an endpoint
danny fabre
I have an issue with a few SX80 have been installed and they drop calls only when it's an audio call and only sometimes. In the past I would have scheduled a few calls after hours and simply capture them all using a syslog over an SSH session to the endpoint but with TC7.x you can't do that anymore, the detailed logs on the website will only capture for 10 minutes at a time. How would you recommend I trouble shoot such an issue.
so you have the actual details this is the disconnections I've seen.
2015-08-10T14:28:22.569-04:00 SalleQuebec9Drouin-905 appl[1234]: 3545314.26 CuilApp   User root(0) about to execute command '/Call/DisconnectAll' from .
2015-08-10T14:28:22.570-04:00 SalleQuebec9Drouin-905 appl[1234]: 3545314.27 MainEvents I: CallDisconnectRequested(p=167) remoteURI='sip:95819824881@10.10.120.12' cause=[normal('') 'LocalDisconnect']
and
2015-08-10T14:28:22.952-04:00 SalleQuebec9Drouin-905 appl[1234]: 3545314.65 CuilApp   User root(0) about to execute command '/CallHistory/Recents Limit: 4' from .
2015-08-10T14:28:22.986-04:00 SalleQuebec9Drouin-905 appl[1234]: 3545314.68 SipPacket I: SIP Msg: Outgoing => BYE, CSeq: 101 BYE, Remote: 10.1.7.10:5061, CallId: 43c067a470462d729aecc0fa4b2e94e7
any help will be appreciated
cheers
Danny
Wayne DeNardi
As you've found, Cisco has decided to disable the root account completely for security reasons.  A new restricted user "remotesupport" can be created on the endpoint.
This user has read access to the system and a limited set of commands that can aid troubleshooting.
The user can be created from the System Recovery section > Remote Support User in the web interface.
Once the user is created a token will be presented.  To decode the token and acquire the password a Technical Assistance Center (TAC) case must be opened.
Have a look at this thread: tc71-now-released-and-available-ciscocom for some ways of executing a full tcpdump and some other troubleshooting commands.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
