12-16-2013 11:40 AM - edited 03-18-2019 02:19 AM
I have a Tanbderg content server V.4, enter the idle mode suddenly, and so this server couldn't be accessed from Network, widows server went down,VGA output disconnected, and the server must be restarted.
please, advice how to solve this issue?
Omar Mahmoud
12-16-2013 12:52 PM
Has this only happened once or does it continue to happen after you booted? Did you recently upgrade? How much space do you have remaining on the server?
12-17-2013 03:45 AM
Hi Michael,
this issue happens every time i booted the serevr.
i didn't upgrade the server since i installed it.
this server have recorded only two small V.C session.
i found that, this issue almost happens when the server tried to logon the windows, but when i goto the bios menu and let the server on this mode, the issue didn't occur.
i tried to use a usb CD-Rom to boot with hiren CD, to use the mini-windows, the same issue happens also.
so, from your view, where's may be the problem?
Omar
12-17-2013 08:39 AM
Just to clarify when you close out the wizard to exit idle mode it doesnt go back into idle until the server is rebooted?
Id most certainly recommend upgradign to 5.3 as there has been a number of bug fixes since rev 4
12-17-2013 03:00 PM
Just last week I had a similar issue as you Omar, one of the TCSs in our cluster was showing status of "idle", and all I had to do was start the TCS Wizard and then cancel out of it to bring it back online.
What generation TCS do you have? If it's..
is the software version you want to upgrade to, those are the current software release versions for each generation of TCS out now.
