Tandberg MXP 6000 continuously restarts after 1 minute
Nguyentiendung
Hi all,
I have a Tandberg MXP 6000. Recently, it continuously restarts after only 1 minute. Does anyone face this problem?
Please help me.
Thanks.
2 Accepted Solutions
I had something similar happen to me with an EX60. Turns out that there was a problem in the sip registration information having the same information for both inside and outside registrars. Factory Reset cleared the problem then reconfigure
Martin Koch
Hello!
Yes, I agree with Richard.
Though for the start up , it would be interesting to see if it still behaves like that if you remove
the external connections like network, isdn, serial first and see if it is some external triggered but.
Then connecting a terminal via the serial port so you might see a bit more why its rebooting.
The command is:
defvalues set factory
or interrupt the boot process and use EEE.
Be aware that you will delete all information on the endpoint, also phonebooks, configuration
and important, the release and option keys. You should have them upfront (found on the endpoint
or via Cisco licensing).
Also upgrading to the latest software is worth giving a try (might require a new release key).
If all that failed and you have a valid service contract (or you have doubts, trouble or questions to any of the steps above) open a case through Cisco TAC.
Please remember to rate helpful responses and identify helpful or correct answers.
Martin Koch
Hello!
The command is:
