Factory Default the system via the CLI.
Connect to the codec via the Serial Port with the following settings:
Data bits: 8
Parity: None
Stop bits: 1
Flow control: None.
Then enter the following command:
xCommand SystemUnit FactoryReset Confirm: Yes
You will then see the following:
FactoryResetConfirmResult (status=OK):
The codec will then automatically reboot.
