05-08-2013 10:25 AM - edited 03-18-2019 01:04 AM
I'm trying to do an upgrade on an EX90. It should be simple, as it's only 6.1.0 to 6.1.1.
When I do it from the web interface, the connection gets reset. Doesn't matter which browser: IE, Firefox, Chrome.
When I try it from WinSCP, logged on as root, it uploads the package to /upgrade, and then just sits there. Does nothing.
No errors show in the CLI console while either is happening, and the MD5 checksum on the file I have matches the MD5 supplied on Cisco.com downloads. Using s52000tc6_1_1.pkg.
Not really sure what the problem could be here. Anyone have any ideas here?
05-08-2013 10:45 AM
Hi Anthony,
its a very strange issue.
do you get any output when login as root on CLI ?
i will recommed you to open a TAC case so that this can be checked remotely
05-08-2013 10:56 AM
Can you attach the current logfiles? These should show upgrade attempts.
Via WEB browser select Diagnostics -> Log Files
05-08-2013 11:01 AM
Apparently no need.
After fighting with it periodically all morning, all I have to do is threaten it by posting the problem here, and then it behaves properly.
Upgrade has been successful. And I have successfully restrained myself from either posting impolite things about it, or smashing it with something.
I did not do anything different this last time than I did several times before, but for the record I was successful using Chrome for the upgrade.
05-08-2013 11:04 AM
Good to hear it worked.
If you want to check what happened with the earlier attempts, you can still send the current logs to understand what failed?
05-08-2013 11:20 AM
05-08-2013 12:20 PM
When the image got upgraded, the logfiles from the previous image are no longer "mounted" in linux, so the logfiles we got now are not the ones when you tried to upgrade. Bottom line : cannot determine from these logs what went wrong
My bad.
