TCU Webstart GUI password
denis.moiseenko
Hello!
Could you please help me!
What is the password for Webstart GUI? I checked all admins guides but I can't find this password.
Thank you in advance!
-Denis
8 Replies 8
Teck Chye Tang
If i am not wrong, the default is no password
I tried no password, tec, TANDBERG but it didn't help.
Hi.
TCU uses two different passwordschemes
1)
u: administrator pw: tec
2)
u: admin  pw:
My best tip would be to try another browser
//Marius
I tried IE, chrome and mozilla. And i tried all scheme you mentioned but it did't help. Anyway it says wrong password.
TCU version?
TCU4.0 (206896)
I just tried with Java 6 Update 41 and I am able to get into the page.   However, when using Java 7, it is not possible.  So please try with Java 6 if you are not using it.
However, i would recommend using VNC to remote access the touch GUI.
Thank you very much for your help!!!
