TelePresence and Webex
billmatthews
I've been reading about the telepresence systems DX, EX, and MX series.  They look perfect for our office to office video conferencing.
But I was wondering about how they integrate with WebEx.  Can I also view and/or share documents using these screens?  For example if at HQ I want to join a webex using my telepresence system, will it also display shared documents?  Or how will it work if I want to share my own documents via a local PC -- can the telepresence system still be my camera?
Thanks!
George Thomas
Level 10
Level 10
Yes you will be able to share documents or do desktop share using the Telepresence endpoints. If the Webex participant shares their screen, you will be able to see that on the Telepresence endpoint as well.
PS: This only works with the cloud solution, the on-prem solution doesnt have the capability yet.
Please rate useful posts.
Thanks George, +5.
Regarding the Cloud solution -- you mean Cloud WebEx correct?  (not some cloud telepresence option)
Thats correct.
