Telepresence Conductor with CUCM
collinks2
Level 5
Level 5
Hello Guys,
I am trying to establish video conference calls with CUCM,Telepresence Conductor and Telepresence Server (vts). I have successfully installed and licensed VTS . I configured the conference bridge (shows Active ) ,conference pool ,conference alias,service preference and location in the telepresence conductor . i have established the sip trunks to both adhoc and rendezvous from the CUCM.
My challenge is that i am seeing an alarm 50118 which indicates that one of the call control trunk is unrecheable. The alarm advised that i should check the location set up in the TC. Please attached the location set up,route pattern set up and others that might be necessary.
However ,in the cucm, the two trunks have registered successfully and their status show up. I am suspecting that i did not correctly set up the following:
i)the incoming alias in the conference alias page (TC)
II) the route patten
i anticipate your kind help
collins
Hello Sharma,
thank you for the response .After coming across the words 'sip' and ' tcp ',one idea came to my mind that i didnt set up security trunk profile in the CUCM.So i navigated to the location page and i changed the settings from TLS to TCP and 5061 to 5060.Guess what? the alarm disappeared.
can you also contribute to this post :https://supportforums.cisco.com/discussion/13246476/cme-router-not-displaying-callers-name
15 Replies 15
Patrick Sparkman
Did you configure CUCM and Conductor per the Conductor Configuration Guide?  There is a section on settings up rendezvous conferences.
Yes  i did. I downloaded the configuration guide for the integration of Conductor with CUCM. The trunks have registered successfully  and their status are showing up. I don't why the alarm is showing the error. See the previous  attachment -location-tc
do you know any  troubleshooting steps ?thanks in anticipation
Do you have any firewall between telepresence conductor or CUCM server?
Can you please clarify what error messages you are getting in video endpoint while dialing the call to your conference bridge.
please check  the call hits on telepresence conductor while dialing from cucm
As per your logs, i am doubtful in location configuration because this error mainly comes when you have the wrong configuration in Location .
Can you please clarify which ip address you used for ad-hoc and rendezvous conference inside the location configuration.
make sure you have created different  ip for both the services in conductor ip settings page.
Total you need 3 ip address .
- one actual conductor
- one adhoc
- one rendezvous
Hello Shama,
Thank you for the updates.
The ip configuration is as follows
Telepresence conductor : 10.108.13.1/24  (this ip was set up during the installation of the virtual machine )
Adhoc ip address is 10.108.13.12/24
Rendezvous ip is 10.108.13.13/24
I have expressway series c and edge for MRA users
I set up meet me conference no -9940.users can dial in and the traffic passes through ADHOC template . i have used the conference button to add users but its still showing ADHOC template. Jabber client can initiate the meet me conference .jabber clients can only use the conference button to add users .
However,i modified the template for  rendezvouz conference and 'permanent meeting can show on the screen; but the alarm is till showing
i hope to read from you
hello guys,
the alarm is still displaying the error-call trunk unreachable. The permanent meeting is working if i dial the meet me no.if i use the conference button to add participants,the ADHOC template will show under the status  .
please can someone help ?
Can you initiate the call and collect some logs files make sure while debugging make it sip and tcp network enable also check box TCP dump mash and share logs with me so i will look into that.
Hello Sharma,
Good to hear your problem is resolved
Hello, thanks a lot.
I have a Telepresence conductor and telepresence server (vts) linked with cisco cucm. Cucm users can call CME users but cant video conference with them. Also cme users can not video conference among themselves due to the lack of dsp which is currently PVDM-32. CUCM users can do video conference .is there no way CME users can make use of the Telepresence Conductor for their video conference ?after 5 minutes cme users have joined the conference, they will be disconnected.
I appreciate your kind input
see attached. the cme user is 3003 and cucm user is 9921. The meet me dial no is 9940. 3003 dialed the meet me dial no but was prompted for pin.As he was typing the pin,there was no reflection on the screen.
I checked the event log in Tconductor,and i saw an error code 'sip unauthenticated'
.so see attached
hello guys,
is there no one in this group? please can some one assist?
Hello Sharma,
Please can you assist me with the cme issue with mobile and remote access users. There is one way video issue from cme to MRA users. MRA users can't see cme users but cme users can see Mra users
Hello Patrick,
it has been a while. I have some challenges trying to establish CME with CUCM. I have some 8945 phones registered with CME while some 8945 and cisco jabber are registered with CUCM.
1.CME 8945 can call CUCM 8945. Both video and audio are working very well.
2. CME 8945 can call cucm jabber but there one way video issue. cisco jabber users can not see cme 8945 users.8945 users can only see cisco jabber users.
3. cucm 8945 users can call cisco jaber users.both video and audio are working very well
4. cme users can join conference with cucm users through telepresence conductor but will log out after 3 minutes
what can be done to fix the issue?
I don't have any experience with CME, but it sounds as if there is an issue going from CME to CUCM, since both CME>Jabber and CME>Conductor fail or not working completely.
