Telepresence Contents Server Installation failed (6.2 BE6K)
neobrutal
HI  all.
I'm Yoong Huh.
I tried to install the TCS 6.2 in BE6K.
When i run the fime of S6_2_vm.exe file, but cannnot process more cause of error.
"Error opening installation log file. Verify that the specified log file location exists and is writable"
I did restart the explorer.exe on taskmanager by MS support forums guide , but it couldn't help.
Have anybody know about these symptom?
I installed Windows Server 2008 R2 Standard SP1 64bit.
Regards.
Yoong Huh.
Patrick Sparkman
Did you following the install guide exactly?
Without knowing more details, I'm guessing you didn't create a second E: partition where the TCS logs and other related application data reside?
Suggest you take a look a the TCS Install Guide if you haven't already.
Patrick Sparkman
Dear Patrick.
Thanks for your reply.
I change the drive path D: to E:, and it worked.
I'm very thanks for your help.
Best Regards.
Yoong Huh.
