Telepresence endpoints & ITL (Security by default)
fjlopezderego
Hi all,
    Does CTS support ITL? It's supported by the IP Phones used by some CTS but, what about the CTS itself? Is it's supported, how can you delete the ITL to migrate the CTS between CUCM clusters?
Thanks!
Manish Gogna
The CTS codecs do not use an ITL, only a CTL if the call manager cluster is running in mixed mode. You may check if a CTL is installed by logging into the CLI and running the command below:
    show security trustlist
Manish
Manish Gogna
Manish
Thanks!!!
