telepresence mibs for codec's
gjwolfcisco1
Hi, does anyone know how the telepresence mib can give you stats on the left/right codec?  I believe it is possible but want to be able to
looking at the cisco-teleprecence-call-mib and do see some variables where you can pull secondary codec but unsure how it would map
to left right center... I'm guessing center would be the primary but is secondary the right and what about the left
any help appreciated
11 Replies 11
Paula Talamo
Hi George,
Check out the article Gonzalo put together here: https://supportforums.cisco.com/docs/DOC-13584
Additional info:
http://www.cisco.com/en/US/docs/telepresence/system_messages/ct_syslog_snmp.html
Paula
Hi Paula, that is just for traps
i tried cli commands as well but only see the primary codec really on sho inventrory or Hardware
there must be a way to pull serials and code levels of primary and secondary units, unsure why sho inventory only shows Primary, then sho secondary doesn't give you much data at all
I was also looking for a way to pull info that would be close to if you manually logged into the gui under device info, you can see center left and right, serial numbers and code versions.
I can't seem to find a shell command that will do the same
Hi George,
SNMP MIB support is available on the  secondary codecs via SNMPv3 contexts. Here is the mapping for these  contexts in current CTS Software:
cts2 = Left codec
cts3 = Right codec
cts4 = Presentation codec
So for example: snmpstatus -v 3 -l authnopriv -a md5 -u -n cts3 -A
For  the call stats using the CISCO-TELEPRESENCE-CALL-MIB, there is a great  write up on how to accomplish this on the docwiki here:  http://docwiki.cisco.com/wiki/Cisco_TelePresence_Call_MIB_Example_Script
Paul
thank you Paul so much for the reply, is that only for v3?  I didn't see i documented maybe I missed it, I did see the call example script but having issue trying to see how exactly the secondaries map out.  I saw it more from traps it seemed when setting the secondaries up.
thank you so much for replying
George
Hi George,
SNMPv2c is supported as well for our mibs, however v2c does not support contexts.
The  call mib is a little more complicated and I will try my best to  explain. To get the information for the secondary codecs you would need  to consult the CtpcStreamSourceType shown below, where secCodec1 is the  left, and secCodec2 is the right, and auxiliary1 is the presentation  codec.
CtpcStreamSourceType ::= TEXTUAL-CONVENTION
    STATUS          current
    DESCRIPTION
        "This textual convention identifies the stream source of a call.
        secCodec1   (1) -- First secondary CODEC stream
        priCodec    (2) -- Primary CODEC stream
        secCodec2   (3) -- Second secondary CODEC stream
        auxiliary1  (4) -- First auxiliary stream like presentation
                           stream.
        secLegacy1  (5) -- Legacy stream generated by first
                           secondary CODEC for legacy system.
        priLegacy   (6) -- Legacy stream generated by Primary CODEC
                           for legacy system.
        secLegacy2  (7) -- Legacy stream generated by second
        auxiliary2  (8) -- Second auxiliary stream."
    SYNTAX          INTEGER  {
                        secCodec1(1),
                        priCodec(2),
                        secCodec2(3),
                        auxiliary1(4),
                        secLegacy1(5),
                        priLegacy(6),
                        secLegacy2(7),
                        auxiliary2(8)
I am assuming that you're looking to get call statistics which mostly come from the ctpcStatStreamSourceTable (shown below)
ctpcStatStreamSourceTable OBJECT-TYPE
    SYNTAX          SEQUENCE OF CtpcStatStreamSourceEntry
    MAX-ACCESS      not-accessible
    STATUS          current
    DESCRIPTION
        "A table for call stream source information."
    ::= { ctpcStatObjects 10 }
ctpcStatStreamSourceEntry OBJECT-TYPE
    SYNTAX          CtpcStatStreamSourceEntry
    STATUS          current
    DESCRIPTION
        "An entry contains a stream source information of a call.
        The entry will be deleted when the corresponding ctpcEntry
        specified by ctpcIndex is removed."
   INDEX           {
                        ctpcIndex,
                        ctpcStreamType,
                        ctpcStreamSource
    ::= { ctpcStatStreamSourceTable 1 }
CtpcStatStreamSourceEntry ::= SEQUENCE {
        ctpcStreamSource         CtpcStreamSourceType,
        ctpcTxActive             TruthValue,
        ctpcTxTotalBytes         Counter64,
        ctpcTxTotalPackets       Counter64,
        ctpcTxLostPackets        Counter64,
        ctpcTxPeriodLostPackets  Gauge32,
        ctpcTxCallLostPackets    Gauge32,
        ctpcTxIDRPackets         Counter64,
        ctpcTxShapingWindow      Gauge32,
        ctpcRxActive             TruthValue,
        ctpcRxTotalBytes         Counter64,
        ctpcRxTotalPackets       Counter64,
        ctpcRxLostPackets        Counter64,
        ctpcRxPeriodLostPackets  Gauge32,
        ctpcRxCallLostPackets    Gauge32,
        ctpcRxOutOfOrderPackets  Counter64,
        ctpcRxDuplicatePackets   Counter64,
        ctpcRxLatePackets        Counter64,
        ctpcRxIDRPackets         Counter64,
        ctpcRxShapingWindow      Gauge32,
        ctpcRxCallAuthFailure    Counter64,
        ctpcAvgPeriodJitter      Unsigned64,
        ctpcAvgCallJitter        Unsigned64,
        ctpcMaxPeriodJitter      Unsigned64,
        ctpcMaxCallJitter        Unsigned64,
        ctpcMaxCallJitterRecTime Unsigned32,
        ctpcTxCodec              CtpcCodecType,
        ctpcTxFrameRate          Unsigned32,
        ctpcRxCodec              CtpcCodecType,
        ctpcRxFrameRate          Unsigned32,
        ctpcTxVideoHorzPixels    Gauge32,
        ctpcTxVideoVertPixels    Gauge32,
        ctpcRxVideoHorzPixels    Gauge32,
        ctpcRxVideoVertPixels    Gauge32
If you wished to view the ctpcAvgCallJitter which is OID 1.3.6.1.4.1.9.9.644.1.4.10.1.23 it would look like this:
1.3.6.1.4.1.9.9.644.1.4.10.1.23.X.Y.Z  where X is basically the call number which comes from  ctpcIndex, Y is  the stream type from ctpcStreamType (1 = Video, 2 = Audio), and Z is the  stream source from CtpcStreamSourceType (1 = Left Codec, 2 = Primary  Codec, 3 = Right codec, and 4 = Presentation codec)
I hope I have explained this clearly, and it is also  important to note that these values are only from the past reboot, and  are not stored after a reboot.
Paul
I notice in V3 if i query either secondary 644 mib is unsuported only 633
is it 644 querery on the main codec able to supply all codec call stats Paul?  mib browser right now I have to decode more to see all the data.
still confused in the v2 example where does teh ctpcindex number come from and where do you get it? the x in abvoe  could you show me an example on the 3 codecs and how you get the numbers?
as I'm still confused if you can pick left right or center in that string why would you use the contexts in v2?  is it just for other functions?
You would use the contexts in for the telepresence system mib for things like peripherial statuses, cable connections, software versions.. etc.
If you're trying to collect call statistics then you should be using the telepresence call mib, and that doesn't need the contexts because all the media goes through the primary codec.
The ctpcindex number comes from the ctpcTable which is essentially a CDR log, it holds the call start time, duration, remote number, SIP call id etc...
Basically when the system resets the ctpcIndex is set to 0, and the first call the value is incremented to 1, the second call it is incremented to 2, and so on...  This way you can get the statistics from not only the active call (the highest number) but historical data as well.
?great info Paul, so from the following mib- is seccodec1 left? and seccodec 2 right
    STATUS          current
    DESCRIPTION
                           stream.
                           for legacy system.
    SYNTAX          INTEGER  {
                        secCodec1(1),
                        priCodec(2),
                        secCodec2(3),
                        auxiliary1(4),
                        secLegacy1(5),
                        priLegacy(6),
                        secLegacy2(7),
                        auxiliary2(8)
Paul I  tried but can't delete the previous and see that it was answered already so thank you very much.  I'm going to be testing some stuff and will have some more questions this has been huge help
