09-20-2011 01:33 PM - edited 03-17-2019 10:30 PM
Hi, does anyone know how the telepresence mib can give you stats on the left/right codec? I believe it is possible but want to be able to
looking at the cisco-teleprecence-call-mib and do see some variables where you can pull secondary codec but unsure how it would map
to left right center... I'm guessing center would be the primary but is secondary the right and what about the left
any help appreciated
09-23-2011 09:22 AM
Hi George,
Check out the article Gonzalo put together here: https://supportforums.cisco.com/docs/DOC-13584
Additional info:
http://www.cisco.com/en/US/docs/telepresence/system_messages/ct_syslog_snmp.html
Paula
09-26-2011 04:57 PM
Hi Paula, that is just for traps
09-26-2011 05:30 PM
i tried cli commands as well but only see the primary codec really on sho inventrory or Hardware
there must be a way to pull serials and code levels of primary and secondary units, unsure why sho inventory only shows Primary, then sho secondary doesn't give you much data at all
I was also looking for a way to pull info that would be close to if you manually logged into the gui under device info, you can see center left and right, serial numbers and code versions.
I can't seem to find a shell command that will do the same
09-30-2011 09:07 AM
Hi George,
SNMP MIB support is available on the secondary codecs via SNMPv3 contexts. Here is the mapping for these contexts in current CTS Software:
cts2 = Left codec
cts3 = Right codec
cts4 = Presentation codec
So for example: snmpstatus -v 3 -l authnopriv -a md5 -u
For the call stats using the CISCO-TELEPRESENCE-CALL-MIB, there is a great write up on how to accomplish this on the docwiki here: http://docwiki.cisco.com/wiki/Cisco_TelePresence_Call_MIB_Example_Script
Paul
09-30-2011 09:57 AM
thank you Paul so much for the reply, is that only for v3? I didn't see i documented maybe I missed it, I did see the call example script but having issue trying to see how exactly the secondaries map out. I saw it more from traps it seemed when setting the secondaries up.
thank you so much for replying
George
09-30-2011 12:08 PM
Hi George,
SNMPv2c is supported as well for our mibs, however v2c does not support contexts.
The call mib is a little more complicated and I will try my best to explain. To get the information for the secondary codecs you would need to consult the CtpcStreamSourceType shown below, where secCodec1 is the left, and secCodec2 is the right, and auxiliary1 is the presentation codec.
CtpcStreamSourceType ::= TEXTUAL-CONVENTION
STATUS current
DESCRIPTION
"This textual convention identifies the stream source of a call.
secCodec1 (1) -- First secondary CODEC stream
priCodec (2) -- Primary CODEC stream
secCodec2 (3) -- Second secondary CODEC stream
auxiliary1 (4) -- First auxiliary stream like presentation
stream.
secLegacy1 (5) -- Legacy stream generated by first
secondary CODEC for legacy system.
priLegacy (6) -- Legacy stream generated by Primary CODEC
for legacy system.
secLegacy2 (7) -- Legacy stream generated by second
auxiliary2 (8) -- Second auxiliary stream."
SYNTAX INTEGER {
secCodec1(1),
priCodec(2),
secCodec2(3),
auxiliary1(4),
secLegacy1(5),
priLegacy(6),
secLegacy2(7),
auxiliary2(8)
I am assuming that you're looking to get call statistics which mostly come from the ctpcStatStreamSourceTable (shown below)
ctpcStatStreamSourceTable OBJECT-TYPE
SYNTAX SEQUENCE OF CtpcStatStreamSourceEntry
MAX-ACCESS not-accessible
STATUS current
DESCRIPTION
"A table for call stream source information."
::= { ctpcStatObjects 10 }
ctpcStatStreamSourceEntry OBJECT-TYPE
SYNTAX CtpcStatStreamSourceEntry
STATUS current
DESCRIPTION
"An entry contains a stream source information of a call.
The entry will be deleted when the corresponding ctpcEntry
specified by ctpcIndex is removed."
INDEX {
ctpcIndex,
ctpcStreamType,
ctpcStreamSource
::= { ctpcStatStreamSourceTable 1 }
CtpcStatStreamSourceEntry ::= SEQUENCE {
ctpcStreamSource CtpcStreamSourceType,
ctpcTxActive TruthValue,
ctpcTxTotalBytes Counter64,
ctpcTxTotalPackets Counter64,
ctpcTxLostPackets Counter64,
ctpcTxPeriodLostPackets Gauge32,
ctpcTxCallLostPackets Gauge32,
ctpcTxIDRPackets Counter64,
ctpcTxShapingWindow Gauge32,
ctpcRxActive TruthValue,
ctpcRxTotalBytes Counter64,
ctpcRxTotalPackets Counter64,
ctpcRxLostPackets Counter64,
ctpcRxPeriodLostPackets Gauge32,
ctpcRxCallLostPackets Gauge32,
ctpcRxOutOfOrderPackets Counter64,
ctpcRxDuplicatePackets Counter64,
ctpcRxLatePackets Counter64,
ctpcRxIDRPackets Counter64,
ctpcRxShapingWindow Gauge32,
ctpcRxCallAuthFailure Counter64,
ctpcAvgPeriodJitter Unsigned64,
ctpcAvgCallJitter Unsigned64,
ctpcMaxPeriodJitter Unsigned64,
ctpcMaxCallJitter Unsigned64,
ctpcMaxCallJitterRecTime Unsigned32,
ctpcTxCodec CtpcCodecType,
ctpcTxFrameRate Unsigned32,
ctpcRxCodec CtpcCodecType,
ctpcRxFrameRate Unsigned32,
ctpcTxVideoHorzPixels Gauge32,
ctpcTxVideoVertPixels Gauge32,
ctpcRxVideoHorzPixels Gauge32,
ctpcRxVideoVertPixels Gauge32
If you wished to view the ctpcAvgCallJitter which is OID 1.3.6.1.4.1.9.9.644.1.4.10.1.23 it would look like this:
1.3.6.1.4.1.9.9.644.1.4.10.1.23.X.Y.Z where X is basically the call number which comes from ctpcIndex, Y is the stream type from ctpcStreamType (1 = Video, 2 = Audio), and Z is the stream source from CtpcStreamSourceType (1 = Left Codec, 2 = Primary Codec, 3 = Right codec, and 4 = Presentation codec)
I hope I have explained this clearly, and it is also important to note that these values are only from the past reboot, and are not stored after a reboot.
Paul
09-30-2011 12:24 PM
I notice in V3 if i query either secondary 644 mib is unsuported only 633
is it 644 querery on the main codec able to supply all codec call stats Paul? mib browser right now I have to decode more to see all the data.
09-30-2011 01:19 PM
still confused in the v2 example where does teh ctpcindex number come from and where do you get it? the x in abvoe could you show me an example on the 3 codecs and how you get the numbers?
as I'm still confused if you can pick left right or center in that string why would you use the contexts in v2? is it just for other functions?
09-30-2011 02:20 PM
You would use the contexts in for the telepresence system mib for things like peripherial statuses, cable connections, software versions.. etc.
If you're trying to collect call statistics then you should be using the telepresence call mib, and that doesn't need the contexts because all the media goes through the primary codec.
The ctpcindex number comes from the ctpcTable which is essentially a CDR log, it holds the call start time, duration, remote number, SIP call id etc...
Basically when the system resets the ctpcIndex is set to 0, and the first call the value is incremented to 1, the second call it is incremented to 2, and so on... This way you can get the statistics from not only the active call (the highest number) but historical data as well.
10-04-2011 11:09 AM
?great info Paul, so from the following mib- is seccodec1 left? and seccodec 2 right
STATUS current
DESCRIPTION
stream.
for legacy system.
SYNTAX INTEGER {
secCodec1(1),
priCodec(2),
secCodec2(3),
auxiliary1(4),
secLegacy1(5),
priLegacy(6),
secLegacy2(7),
auxiliary2(8)
10-04-2011 11:35 AM
Paul I tried but can't delete the previous and see that it was answered already so thank you very much. I'm going to be testing some stuff and will have some more questions this has been huge help
