Telepresence Server & Telepresence Conductor Upgrade
ln33147
Level 4
Level 4
Dears,
We will be upgrading our Telepresence Conductor from version 4.2 to version 4.3.6 and our Telepresence Server from 4.3 to 4.4.
Could you please advise which server needs to be upgraded first and how to get a new Release Key for the Telepresence Conductor.
Thank you in advance.
Lara
5 Replies 5
JFerello
You will not need a new release key for either, if they ask for a release key during the upgrade, just copy and paste the existing one.  It does not matter which you upgrade first, they are not software dependent to each other.
Justin Ferello
Thank you Justin for taking the time to respond.
Could you please advise where we can get the existing one.
Thank you,
Lara
On the Conductor, the "current" release key should be on the upgrade page.
Justin Ferello
Hello Justin,
Thank you.
Could you please advise on the downgrade procedure, if needed.
Thank you,
Lara
Downgrading is the same as upgrading - you're just installing "new" software. Whether you are going to a newer or older version doesn't change the process.
