09-03-2014 09:23 AM - edited 03-18-2019 03:22 AM
Hello Forum,
Would any one stored the API for TMS 14.1.1 referenced as version 10 in version history ? There is no way to find it on the Cisco Site. There is a jump from 13.2 to 14.2 and no logs for 14.1.1.
Thanks if you can post it. I offer a coffee !
Cecile
09-03-2014 05:22 PM
Looking at the release notes, there is not a big difference between the Booking API in 14.1.1 and 14.2 - so the 14.2 guide would still be appropriate.
The few changes that were made are listed on pages 4 and 5 of the TMS 14.2 release notes, so just beware of those differences when using the API.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
09-04-2014 02:12 AM
Hello Wayne,
Thanks for your reply. I read the release notes but hte big difference between 14.1.1 and 14.2 is TMS Scheduler replaced by Smart Scheduler. I wondered if there would be any further impact with TMSPE ?
If not, it will be perfect.
Cecile
09-04-2014 11:07 PM
Yes, the actual scheduler has changed, but the API is still noted as being the same, so using the API guide for 14.2 should still work fine for 14.1.1 (apart from the few differences noted above).
Wayne
