TMS 14.1.1 TMSSnmpService
mnour401917_2
After upgrading TMS to 14.1.1, i have a problem with TMSSnmpService.
I get this alert on TMS.
"The service TMSSnmpService is not running on server"  I have restarted the service and rebooted server, any one seen this issue before?
Mohammed
8 Replies 8
Jens Didriksen
Level 9
Level 9
It's a known issue, bug number CSCue00035 - fix is expected in 14.1.2 which is, at this stage, due out in April.
No need to re-boot the server, just re-starting service is fine.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Thanks Jens. Do you know if this will case any issues on 14.1.1 functionality?
Mohammed
Hasn't caused any issues for me, but I do re-start the service as soon as I see the TMS ticket.
This is not happening very often for me though, only once in a while.
Also see
https://supportforums.cisco.com/message/3818666#3818666
for a possible fix. (I don't dare to play around with .Net due to other issues I had with a version of .Net - long story).
/jens
I confirm that you are hit by this bug and the release that should contain the fix is 14.2
/Magnus
TMS 14.2 was released today and is now available on CCO (cisco.com).
-Kjetil
Hi Kjetil,
I am having similar problems to the one reported by Mohammed.
I have upgraded to TMS 14.2.2. Under the Portal tab I see 8 opened tickets.
They are all similar. The tickets tell me various services are not running. But when I look under services, I either see the mentioned service is not displayed or that the mentioned service is already running. Stopping and starting the services does not see to solve the problem.
Below are the tickets:
TMS Service Not Running.
Ticket # :
9896
Acknowledge
Delete
Status :
Open
Description :
The service   TMSSchedulerService is not running on server WIN-OQ7ONB783UH.
How to fix this problem :
Log on to the server   and open Control Panel, Administrative Tools, Services and start service.
First Reported :
7/6/2013 1:18:03 PM
Last Reported :
7/6/2013 1:49:03 PM
User Comments :
Ticket # :
9897
Acknowledge
Delete
Status :
Open
Description :
The service   TMSPLCMDirectoryService is not running on server WIN-OQ7ONB783UH.
First Reported :
7/6/2013 1:18:03 PM
Last Reported :
7/6/2013 1:49:03 PM
User Comments :
Unable to Communicate with the Provisioning Extension
Ticket # :
9894
Acknowledge
Delete
Status :
Open
Description :
Verify that the TMS   Provisioning Extension service is running and that you can successfully   access the menus under Systems > Provisioning.
Log on to the server   and open Control Panel, Administrative Tools, Services and restart the TMS   Provisioning Extension service.
First Reported :
7/6/2013 1:18:00 PM
Last Reported :
7/6/2013 1:48:41 PM
User Comments :
Ticket # :
9895
Acknowledge
Delete
Status :
Open
Description :
The service   TMSLiveService is not running on server WIN-OQ7ONB783UH.
First Reported :
7/6/2013 1:18:03 PM
Last Reported :
7/6/2013 1:49:03 PM
User Comments :
Ticket # :
9900
Acknowledge
Delete
Status :
Open
Description :
The service   TMSServerDiagnostics is not running on server WIN-OQ7ONB783UH.
First Reported :
7/6/2013 1:18:03 PM
Last Reported :
7/6/2013 1:49:03 PM
User Comments :
New Movi Client Software Version Available
Ticket # :
127
Acknowledge
Delete
Status :
Open
Description :
First Reported :
10/26/2012 12:00:33   AM
Last Reported :
User Comments :
Ticket # :
9898
Acknowledge
Delete
Status :
Open
Description :
The service   TMSSnmpService is not running on server WIN-OQ7ONB783UH.
First Reported :
7/6/2013 1:18:03 PM
Last Reported :
7/6/2013 1:49:03 PM
User Comments :
Ticket # :
9899
Acknowledge
Delete
Status :
Open
Description :
The service   TMSDatabaseScannerService is not running on server WIN-OQ7ONB783UH.
First Reported :
7/6/2013 1:18:03 PM
Last Reported :
7/6/2013 1:49:03 PM
User Comments :
Here are the services running
TMSDatabaseScannerServices
TMSLiveService
TMSSchedulerService
TMSServerDiagosticsService
TMSSnmpServce
Thanks for any help you might offer
George
In general I would recomend to open a new thread instead of making old ones longer.
Can it be that you renamed the server at one point?
Do you run a cluster or only a single instance?
Is it a false alarm or are the services really not running on that server?
Did you restart the server and checked if the alarms are gone?
If you go to:
You are here: Administrative Tools > TMS Server Maintenance
Can you make a screenshot of:
TMS Services Status
and afterwards click on clear.
Does the error still show (might be handy to do a reboot afterwards as well)
Thanks for the reply
I believe the problem was I entered and incrorrect Host Name under Administration Tools --> Configuratoin settings --> Provisioning Extension Settings -->SMTP Host Name.
Correcting this entry seemed to eliminate the  problem.
