TMS 15.1 does not respect Preferred Protocol in Routing
Jens Didriksen
Level 9
Level 9
TMS 15.1
C-series: TC7.2.1, TC7.3.4
SX20 and 80: TC7.3.4 and EC8.01
All end-points registered to VCS with both H.323 and SIP addresses.
TMS Conference Settings/Advanced Settings: Preferred Protocol in Routing: H.323
Default call protocol set on all end-points: H.323
When creating new conferences, connection setting is set as "SIP" despite the above preference, changing this to H.323 does not change the dial string from Alias@domain to the preferred Alias without any suffix.
I can't see anything in the TMS open/resolved issues list, so, before I open a case with TAC, has anyone else already opened a case, or found a way to fix this? (We did not see this issue in TMS 14.4.x)
Thanks/cheers
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Hi Jens,
I can't seem to replicate your issue here.  I have endpoints dual registered on my VCSes, and when scheduling them in TMS 15.1.0 it's showing as H.323 in the Connection Settings.
If I click the "Settings" under Action on the far right hand side of the Connections Settings screen in TMS, I can change it to "IP - SIP" and the addresses used change to SIP, and if I change it back to "IP - H.323", it changes back to the H.323 addresses.
Wayne
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Hi Jens,
Wayne
Wayne
Thanks Wayne, very much appreciated. :)
Too make this even stranger; it appears the Singapore based techs are not having this issue. Starting to wonder if it's something as simple as a browser issue, better look into that when back at work in the morning.
/jens
I did submit a "possible bug" in 15.1 report to Cisco TAC a while back, however, upgrading TMS to 15.2 fixed the issue for us.
/jens
