TMS 15.7.0 INSTALL
Chet Cronin
Level 4
Level 4
I am trying to perform a new TMS VM installation on Windows 2016.
TMS 15.7.0.
I have download the install guide.
Problem is running the installation getting past the SQL portion.
OK the guide says to install Native Client 11 so I went to the MS site and downloaded msodbcsql.msi.
Well that didn't work.
Then per the guide I was going to download t Native Client 13.0.1601.5 or later version (Page 16).
Well I went to MS site again and WoW many files?   What exactly are the correct files to install on the Windows Server hosting the TMS APP????
I have an external SQL server running 2012 and I want to point the TMS server to that one?
Any help is appreciated.
I don't want to have SQL and TMS on the same server ???
Chet Cronin
Shashank Mahajan
Hi Chet,
As you already have an external SQL Server 2012, you can install the SQL Native Client version 11.0 for SQL Server 2012 from the following link:
https://www.microsoft.com/en-us/download/details.aspx?id=50402
sqlncli.msi is the installation file for SQL Native Client.
Shashank
Shashank Mahajan
Hi Chet,
Shashank
