03-30-2020 08:14 AM
Hi All,
I hope this is in the correct Group.....Is there a way (if so how please) of adding an API (also how do i write and add this) to TMS which will retrieve IP Address, System Status, MAC Address, Serial Number and Model of all endpoints registered on TMS?
03-30-2020 11:36 AM
This information/report can be done by using the "system overview" feature in TMS. No special API required - it's built in. All of the information you are asking for is available. See below from the help:
On this page, you can compare specific parameters on specific systems by having them presented in a table view. The table can also be exported to Excel for further processing.
After selecting the desired combination of systems and parameters, click View at the bottom of the page.
When a table has been generated, Export to Excel becomes available.
03-30-2020 01:02 PM
Hi Patrick,
Thank you for your swift response. That has indeed generated the information that i required. Many thanks for your help.
03-31-2020 01:04 AM
Hi Patrick, Is there an specific API command that another software package can use to interrogate TMS to extract this information?
03-31-2020 01:32 AM - edited 03-31-2020 01:32 AM
Doc's title is confusing but I believe your answer is in the "Cisco TelePresence Management Suite Extension Booking API". Look particularly at the "Remote Setup API Reference".
04-07-2020 12:33 AM
Thanks for the link.
What API command do I use to recall the IP Address, Status, MAC Address, Serial Number and Model? SystemStatus can be used for Status and SystemType can be used for model. How about the other 3 details?
04-07-2020 02:48 AM
If you can't get all the info you need from TMS, query the endpoint directly then.
First, retrieve the complete list of systems from TMS with GetSystems command and extract the WebInterfaceURL from all TMSSystem objects returned. For each of them, visit the http(s)://<ip-address>/status.xml page or use getxml to retrieve exactly what you need.
Take a look at the codec API, page20 :
04-07-2020 03:46 AM
Thank you.
My task is to use an asset management software to access TMS to retrieve a list of the IP Address, Status, MAC Address, Serial Number and Model of every system on TMS. Is this even possible? It needs to be automated so once the asset management software has its schedule set then the task will auto complete on a monthly basis. I apologise if I'm not following what you are advising.
