Tms Installation with error.
Bar1s
Hi everyone,
I am trouble with Tms 13.1.2 installation. I am getting this error when ldap server installation part.
Also problem show up Tms Agent and Provisioning part. Any idea ?
2 Accepted Solutions
Magnus Ohm
Is this a clean installation on what server os (I assume 2008 64 bit) or is it an upgrade? If it's an upgrade what version are you upgrading from? If you re-run the installer do you see the same error every time?
As kjetil is saying it would be interesting to check what the logs are saying but when it comes down to sharing logs I strongly recommend you to open a TAC case if this issue is consistent. It might be worth checking the GP's and / or if there might be any security software blocking the installation.
The windows eventviewer might also help you find what is going on.
/Magnus
I have seen this screen a few times.
Are you installing / upgrading using a domain admin account vs a local admin account? I have seen the install hang at the ldap install section.
Also, do you have any anti-virus software installed? If so, disable it, uninstall everything (including openDS), and try the install/upgrade again.
10 Replies 10
Kjetil Ree
Do the log files referred to in the error message say anything useful?
Kjetil
Hello All,
It was clean install Windows 2008 x64.
I have not any antivirus nor any security program. I am local admin user for this server, normally i am a domain user.
I am getting this error messages at OpenDsConfigLog.txt
TMPPATCH: C:\Program Files (x86)\TANDBERG\TMS\provisioning\database-patches\tmp
~1: C:\Program Files (x86)\TANDBERG\TMS\provisioning
A subdirectory or file C:\Program Files (x86)\TANDBERG\TMS\provisioning\database-patches\tmp already exists.
upgrade type:
The service name is invalid.
More help is available by typing NET HELPMSG 2185.
Disable replication
Establishing connections .....
Could not connect to localhost:4444.  Check that the server is running and
that the provided credentials are valid.
Error details:
javax.naming.CommunicationException: localhost:4444 [Root exception is
java.net.ConnectException: Connection refused: connect]
set log rotation policy and restrict access
wait 1
Connect Error
Result Code:  91 (Connect Error)
wait 2
Connect Error
wait 3
Connect Error
wait 4
Connect Error
wait 5
Connect Error
wait 6
Connect Error
wait 7
Connect Error
wait 8
Connect Error
wait 9
Connect Error
wait 10
Connect Error
Unable to start opends, will try again ..
C:\Program Files (x86)\TANDBERG\TMS\Provisioning\OpenDs-2.0\logs\native-windows.out
        1 file(s) copied.
And  Opends_version.txt
OpenDS Directory Server 2.0.0
Build ID: 20090630082738Z
Major Version: 2
Minor Version: 0
Point Version: 0
Version Qualifier:
Revision Number: 5492
URL Repository: file:///svn-mirror/branches/b2.0
Fix IDs:
Debug Build: false
Build OS: SunOS 5.10 x86
Build User: builds
Build Java Version: 1.5.0_12
Build Java Vendor: Sun Microsystems Inc.
Build JVM Version: 1.5.0_12-b04
Build JVM Vendor: Sun Microsystems Inc.
Upgrade Event IDs: 1,2,3,4,5,6,7,8,9
           Name                 Build number         Revision number
Extension: snmp-mib2605         2.0.0                5492
Magnus Ohm
/Magnus
Hi gents,
This totally up to gp security.
So I did clean install with no domain.
Now i haven' t problem.
Baris.
hi baris,
I have same problem with you, the message always appears, I try to install on server 2008 and 2003, the message still pop up, please... give my step by step guide to fix it.
Hi Andrie,
I just simply install Win2008 x64 standart edition without join domain and install Tms without any error. I didnt any special configuration.
Also I am agree with Magnus new Provisioning Extension is better choice. I am strongly suggest new Provisioning Extension.
Baris.
Magnus Ohm
I would recommend you to ignore any errors with opends and setup the new provisioning extension if you plan to setup provisioning. Then you wont have to migrate later.
/Magnus
andrie prabudhi
Hi all,
it works, I am install on win2008 server without join domain and disable firewall windows, I hope ok too when using win2003,
I have another question again, 2 days ago I was uninstall tms when the errors show up, and then I try to reinstall again, but the tms always ask sql user&pass, while sql removed along tms, any part missing when I remove them?
thx
Bar1s
Hi Andrie,
Database files not removed when you uninstalling Sql or Tms.
So setup will ask password for existing database.
Baris.
