TMS license key
llopez
Hello
I have a client that would like to upgrade from Cisco TMS 15.2. to TMS 15.10 on the same server BE6K (M4), ¿Can I still using the license I received on TMS 15.2?  or ¿ Do I need to buy a new license key?
Thanks for your time
Aman Soi
Hi ,
I suppose you are referring to Release key  which is required for doing any major upgrades .
You can refer the DOC.
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tms/license_info/78-19878-01_Cisco_TMS_licenses_keys.pdf
Adding keys during Cisco TMS upgrades:
Release key must be entered during installation to complete upgrades between major versions of Cisco
TMS. When upgrading between minor versions, the existing release key is retained and reused
automatically.
regds,
aman
